- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Recommendation for Defender 110 300tdi Exhaust? |
cornish rattler
Yeah for some reason paddocks only do the straight through section in stainless steel not in mild steel or buy a full mild steel exhaust complete but with both silancers which we did so to use part of the old 2.5td ( nearly new ) exhaust and the new 200tdi rear section we bought with the new down pipe just to cut up for the flanges and bends to make the new side exit to work over the rear chassis and to bent in the right place to come out of the rear wing Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
24th Jun 2014 12:27am |
