Home > Maintenance & Modifications > Bilstein b16 ride control dampers |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Can be supplied through overlander4x4.com
We have them fitted in a 90 and they are incredibly good. Here the vehicle in a German forum. The conversion of a 90 ex MOD to a beloved dreamcar http://www.offroad-forum.de/viewtopic.php?...;start=150 WANTED: SII or SIII in max 1.5k |
12th Jun 2014 12:00pm |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
Cheers, I've bought some stuff off Brendan before so hopefully he sees this! 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top. 2014 90 XS SW 2.2. |
12th Jun 2014 12:17pm |
Peter just send me an email with exactly what you require and will try and sort things out for you.
Have not used them myself, can not give any advice about them. However, Peter rates them and a friend of ours called Matthew rates them as well so think they will be a good choice. We are in Germany next week so if need be can bring a set back with us. Brendan |
12th Jun 2014 12:57pm |
PM sent Brendan. thanks 2001 90 HT 6.0LS/6spdAuto.
12th Jun 2014 10:10pm |
Quiksilver Member Since: 27 Dec 2015 Location: West Yorkshire Posts: 6 |
I've been looking at the Bilstein B16 dampers on a few sites but no where does it seem to say what the ride adjustment is.
Do the B16 lower the ride height in comfort mode? And what is the drop in ride height once you opt for sport setting? Thanks |
11th Mar 2016 8:01pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
If it's only shockers, I don't reckon there'd be any change in ride "height", just the ride "characteristics", soft/hard etc?
Pickles. |
11th Mar 2016 10:29pm |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 |
Pickles, the B16 is a selectable suspension, it has sport and comfort modes, just select with the touch of a button.
I think there is a change in height, 'tho I don't have them myself. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
11th Mar 2016 10:37pm |
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 |
Good Morning Gents, had the full kit fitted to my 90 back in October 14.
The system is very good and you can really tell the difference between Sport, Normal and Soft! The system can be calibrated and customised using your IPad connected using the Bluetooth module. The system doesn't reduce the height of the vehicle in sport mode but changes the speed and sensitivity of the shock absorbers. If you want to lower your truck you need to run lower springs. If I had the choice and money again would probably look at the full air suspension kit by ACR ( I think). Mega money but awesome system. Cheers WYL 2015 90 Keeper 2005 R300 Keeper 2019 XC40 Shopping Trolley 2008 110 XS Utility (Friday Build) Gone! |
12th Mar 2016 8:04am |
