![]() | Home > Tdi > 200tdi upgrades |
How many miles does the engine have?
If its had a hard life and is quite oily or smokey then tuning can kill a high mileage engine. Just look on ebay for how many 200's are for sale with "tweaked pump and turbo, Needs new head" I have a factory fit 200Tdi and the only modification I have done is black silicone hoses and that because my old ones were completely saturated with oil. Difference? Barely noticeable, however I am averaging 33mpg and regularly hit 36mpg so its not all bad. Might be best to start small and just give it a damn good service, give it some oil conditioner and run it for a few weeks. After that maybe look at a drop in double thickness intercooler? This guy did it and he seems happy with the results = Just remember it is a big, low revving, torque bias engine so any tuning upgrade you do is like giving running shoes to a weight lifter, it will do it, but it wont be too happy. Mabie get in contact with BAS and ask them what they would recommend based on your usage? |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 183 ![]() ![]() ![]() |
For the money they cost I wouldnt bother buying a bigger intercooler. I have done it a couple of times and always leaves me a little disappointed. The biggest difference is the free one with a small tweak of the pump. it just eliminates that flat spot when pulling away, especially with a cold engine. Obvious thing is that you dont want it smoking, it only makes it look ill.
william127 Member Since: 29 Sep 2013 Location: ware, herts Posts: 16 ![]() |
Thanks for the advice, i will be going to billing soon and i think i will have a good walk round the club stands and talk to people who have 200s, see what works for them. I will start with the full service, the engine is in good nick, it had the head off and the valves reseated about 10k ago, the pistons checked and measursd and various seals changed.
Clean the existing intercooler with parafin. It makes a huge difference on an older engine. Darren
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I fitted an ALI Sports full size inter cooler onto a 200 tdi and silicone pipes and I noticed a huge difference, especially when pulling uphill.
Have a look here
Tuning Land Rover Tdi engines article with pictures diagrams and more information than you could possibility need http://www.l4ndrover.co.uk/_downloads/Tuni..._Rev_2.pdf |
Thats a great link, thanks, and its downloaded so i will be able to use it where the truck actually is!
![]() I cleaned out the intercooler about 10k miles ago, thanks. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Go carefull with large diamiter exhausts, some back pressureis needed and used by the turbo to maintain a ballance pressure between the exhaust side and compressor side which keeps the oil in the barings and stops it from blowing out either from the compressor side or exhaust side..
Pete |
