![]() | Home > Td5 > Started to shudder and a loss of power |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
First things to do is unplug your MAF sensor and give it a whirl, sounds like something similar to what ii had next check the red plug on the ECU for oil ingress..
THF Member Since: 18 Jul 2012 Location: Sunny N Hants or Pompey Posts: 83 ![]() ![]() ![]() |
Ttuck3r, Thanks for that I'll give it a go at the weekend.
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
+1 for the MAF sensor. When it gives faulty readings the engine will go into reduce performance mode, hence the lack of power. Turning the ignition off and back gets you back into normal mode until the next faulty reading.
You can run a test by putting a voltmeter between the middle pin and ground when engine on but idle. It should read 2v, if it's off by more than ~0.3v I'd chuck it.. Flatdog are selling MAFs at £39 at the moment. ![]() Whilst your under the bonnet, spray some WD40 on the Turbo Waste gate actuator where the rod comes out, should help prevent it from seizing up in the future. ![]() |
MRD1990,
Diolch!! |
TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89 ![]() ![]() ![]() |
Agree with above advice, MAF faults can bring varied symptoms. In my experience, a lack of power (like no turbo) until certain revs then it will pick up. Or on hills having to change down a gear to keep going!!
A shudder and loss of power - like hitting a rev limiter or governor - would be the wastegate actuator sticking. There is a great video on youtube put up by one of the tuning sponsors showing how simple it is to test. Re the MAF on flatdog, is it genuine parts? Good for that money if it is. Always recommend fitting a genuine Siemens VDO part. Others just don't last. Just my tuppence worth. |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 ![]() ![]() ![]() |
Hi THF, I had very similar symptoms in my td5 90. Thanks to the information I read on defender2.net I replaced my maf with a genuine one from duckworths. Problem solved in less than 5 minutes
