Home > Maintenance & Modifications > Just ordered a NK engine blanket - do they make a difference |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Yes thanks Lambley, will have to look at that next. Yes being a hardtop it is basic with a now thinner than it used to be plastic "carpet" in the cab area so not much in the way of sound proofing as standard. 110 Hardtop
4th Jun 2014 7:11am |
That would have bought you many, many pairs of these: |
4th Jun 2014 9:05am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Pardon?
4th Jun 2014 9:25am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Lambley, did your bell housing have the standard landrover piece of sound proofing on it? i'm sure mine has some kind of factory fit soundproof on it! If so do you remove that? or does the NK BHB wrap around that too? My 109 thread my youtube channel |
4th Jun 2014 9:30am |
Land Rover are all ready on the case! When I was at Eastnor the other weekend L R Experience were dropping these in your bag when you made a purchase on their stand.
Click image to enlarge |
4th Jun 2014 10:04am |
From memory there wasn't any soundproofing on mine before I fitted the blanket. I changed the transfer box to alter the gearing so the tunnel was out, but I can't remember seeing anything other than the metal casing to the box and transfer so I'm sure there wasn't any, do you mean the small piece of foam that sits on the top?
Don't get me wrong, when I said its difficult to fit, it wasn't that bad, it's just a case of spending half an hour getting the blanket into position and tie wrapping it. The blanket is fairly stiff due to the lead within. |
4th Jun 2014 10:07am |
