- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Gave my 90 a service today |
cornish rattler
Gave my 90 a service today | |
Hi guys
I finally got round to servicing my 90 today after 4 months of ownership as I had a few other important jobs to do first on my 90, and I am glad I did it when I did as the engine oil was like water, the gearbox oil was pink in colour ( water in oil ) and both axles oils was creamy looking ( water in oil ) with the front axle having signs of metal in it which I think is coming from a worn n/s C.V. joint so for now I have replaced all the oils then once I have been to billing I will replace both C.V.'s as I have found the o/s railko bush worn aswell so I will de everything in one go inc both sides aswell as replace all wheel bearings but other than that everything is ok Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
31st May 2014 8:08pm |
