![]() | Home > Td5 > Fuel filter draining |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Have never had that happen ! I don't usually drain mine I just unscrew it and fill the new one up and screw it on. I usually buy a new drain screw as they have a habit of shearing off when you do it up.
As far as I know there is a one way valve in the filter head,you may have a problem with that. 2005 Td5 90 XS Steve |
Roy l Member Since: 01 Aug 2013 Location: Surrey Posts: 9 ![]() ![]() ![]() |
Thanks for replying.
When you unscrew it, presumably there's quite a bit of fuel spillage. Is it just a case of being quick to reduce the amount of loss? Defender Virgin - go gentle with me! |
No I don't get any fuel running out of the filter head once the filter is removed. If this is what you are getting I would be inclined to get the new filter filled with fuel and ready to fit and swap it over quickly then do the purge sequence and try and restart engine,hopefully there will be no air in the system.
I think you May have problem with your filter head. 2005 Td5 90 XS Steve |
