![]() | Home > Td5 > Unknown connectors. |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
![]() Click image to enlarge Just when I thought I had familiarised myself with the car, out of nowhere pops these two connectors, okay, from behind the nearside headlamp. What are they, what do they do? Everything I have, works, so am I missing something? It wasn't me! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
For electrically levelling headlights, and the alarm BBUS unit
That were quick.
I have neither of those, however I have acquired a BBUS from a P38, so hopefully that'll be plug and play. Headlight levellers, nah! It wasn't me! |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
BBUS and alarm horn not headlamp levellers??
I go with bbus and horn , leveller plug is smaller with more wires
Horn is plugged in and working, so not that. It wasn't me!
is yours hard top or pick up?
is there two horns in there (one "get out of my way horn" ) and one alarm horn |
110 csw. Only one horn that I know of, two if you count my novelty klaxon. It wasn't me!
think there should be two , one mounted to front headlight panel so it's in between indicator and side light and one up in top left hand corner as your looking at pic so really up beside rad but inside wing ( if that makes sense )
I'll stick a meter on it and see if it powers up when I hit the horn switch. It wasn't me!
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
AFAIK, Td5s are wired for two horns (Hi/Lo tones) but typically only have one (near side) fitted. I found my off side horn multiplug (purple/black trace + earth) tucked up in the offside inner wing (2005 110 SW)
As mentioned, the other two plugs are for the battery backed up alarm sounder (brown plug 4 black wires) and a non battery backed up siren (orange/black trace+earth). From what I can work out, Td5s alarm sounder is the horn but in theory you can add both a BBUS & a non battery backed up siren in addition to perhaps a second horn.... that'll keep them guessing, particularly if some are fitted in non standard locations. P38 part should work fine but worth checking how well the unit's battery holds its charge after all these years. Jon - 110 td5 [sold]. Currently Defenderless. |
