Home > Td5 > Air intake position |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5786 |
But even if not a Td5 it would be a 300Tdi. So air intake should be on same side as a Td5.
22nd May 2014 12:34pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
Good point!
It is very stange! |
22nd May 2014 1:17pm |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 |
Had a look, air box is there but the pipe work is missing so it's just drawing air straight in from behind the engine, not sure if this is an issue, apart from affecting my OCD!
Cannot believe I missed this when I looked it over, sometimes the most obvious is the hardest to spot! |
24th May 2014 8:10am |
td5
missing from here see gallery part pic |
24th May 2014 1:02pm |
Yes spot on that's what is missing
24th May 2014 2:13pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Click image to enlarge |
25th May 2014 6:35am |
