![]() | Home > Tdi > Security for Spare wheel / tyre |
If you're that worried get a good quality motorbike cable/chain lock and thread it through the holes of the modulars and attach it to the wheel carrier or an eye bolt that you'll fix to the back door.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Yeah I know what you mean but think the bracket would be neater
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Changed your mind then? ![]() ![]() Click image to enlarge http://www.defender2.net/forum/topic19033....l+security If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Well no not really I still don't like the spare on the back door but because its a county spec the spare won't fit on the rear bulkhead which is where I would like it as the side facing seats are in the way as they fit pretty close to the bulkhead where as bench seats and front facing rear seats fit further away and a swing away is no good as i tow a trailer
Stick it on the bonnet
Few posts on bonnet mounting.....
http://www.defender2.net/forum/topic14555....are+bonnet http://www.defender2.net/forum/topic22428....are+bonnet If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Sorry but I would rather keep it on the rear door than fit it on the bonnet as it bawkes your view and makes the bonnet very heavy.
think I have two choices either keep it on the back door or get rid of the side facing seats and fit it on the rear bulkhead which I would prefer ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
