Home > Td5 > Trailer indication light illuminating when inductors are use
ChrisJ
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi guys,
This is more of an annoyance than a problem but your help would be appreciated.
When indicating left or right, the green trailer indication light comes on on the dash for a second or two and goes out.
Any idea why?
As said more of me wondering why, if it's supposed to etc than a problem.
Post #330862 13th May 2014 8:25pm
Waldo
I have this as well.... but no idea why
Interested to see the replies Defender 90 XS TD5 (03 Reg)
Post #330864 13th May 2014 8:27pm
Lou Sparts
Trailer light flashes with the first flash of the indicators purely as a lamp test. 2005 Td5 90 XS
Steve
Post #330865 13th May 2014 8:28pm
ChrisJ
Ah right, I'm rather new to this defender lark!!
Thank you.
Post #330867 13th May 2014 8:32pm
Whizzer
2006 Defender 90 Td5 XS CSW Cairns Blue
Mine keeps flashing?
Post #330869 13th May 2014 8:42pm
Get this:
http://www.ebay.co.uk/itm/RDX-4-Pin-Flashe...35c5dcf256
Let's you fit LED lights, or keep incandescent regular lights.
Stops the ingle flash but still works with trailer connected as it should.
Got mine last week, works a treat!
Post #330877 13th May 2014 9:04pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I fitted a BoltOnBits set of LED lights to mine and the set came with a new flasher unit, but after fitting the rate of flash seemed very slow, I called them but they just said "it's within tolerance - so it's legal, but we're working on a new version that will flash quicker because we've had a few calls now!"
Custom90steve - does yours work without the trailer light and flash at a decent rate? If so they might have sorted it.
Post #330922 14th May 2014 5:30am
Works without the trailer light yes, flash rate seems just a tad slower but nothing to complain about at all.
I prefer it actually.
By this I mean a very very slight difference.
Thumbs Up
Post #330956 14th May 2014 9:41am
It's worth bearing in mind the voltage difference on setting the relay varies which also has an affect.
12v with ignition or 14v with engine running.
I set mine at first with ignition then found when the engine was running the trailer light started coming on where with the ignition it didn't.
So, as you'll be indicating with the engine running whilst driving I'd advise setting it with the engine running.
It should be set so the trailer light is just turned off, so very small increments of movement on the adjustment knob.
Iirc clockwise will bring the light on and anticlockwise off.
I'm very pleased with it anyway. Thumbs Up
Post #330986 14th May 2014 2:33pm
gilarion
Is the RDX relay a WIPAC relay with an RDX badge stuck on, as they look identical, RDX says it has all its electrics specially made for them but I am not sure that is true as to have small items specially made by a component factory you have to order ten of thousands and RDX markets are not that big!
Reason for bringing it up is the WIPAC one is less then half the price!
Post #331006 14th May 2014 4:41pm
But does the Wipac version have the same functionality?
Post #331023 14th May 2014 5:44pm
gilarion
It seems to work OK with LED and incandent lights and has the little knurled control knob exactly in the same place as the RDX one has, its just worrying that RDX seems to have just stuck a stuck label on the side of the relay where as if it was specially made for them it would have the RDX logo either printed on or embossed in the plastic.
Post #331037 14th May 2014 6:29pm
munch90
I found flash looked slow with the rdx , yes still within flash rate regulation but I thought it looked like a old mini bi metal flasher rate bit old fashioned looking , so changed back to one ive used for years
Post #331039 14th May 2014 6:38pm
The lights themselves have RDX imprinted on them like others, same with the LUX NAS lights too.
Post #331046 14th May 2014 6:53pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
@munch90
See if you can buy an LED relay from Simon at MPS trading, he's a sponsor on here. I bought a set of Wipac LEDs from him and they came with a relay that has a small knob to adjust the flash rate.
Much better than the RDX unit I had on my previous Defender with RDX LEDs. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #331088 14th May 2014 8:51pm
