Home > Tdi > Stiff Cooling Fan
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Stiff Cooling Fan
Hi guys
As you know we tried to go to an event yesterday but it was canceled when we arrived there, anyway just before we got there we stopped off at a petrol station to re-fit the cooling fan ( fan removed for normal driving ) an when I fitted it back on and tightened up i spun the fan and it stopped pretty quick.
does this mean my fan is goosed Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #330505 12th May 2014 11:44am
munch90
they will stop quick when first turned
WITH ENGINE OFF
spin the fan by hand for a while and it should get easier to spin to the point of it will keeping spinning for a short time when you let go of it
that's why fans make a lot more noise when you first start up cold until they free up (normally go quiet after few seconds )
Post #330507 12th May 2014 12:08pm
cornish rattler
Are right I see Wink Graham
Post #330573 12th May 2014 6:30pm
g-mack
sorry for hijack, is the 300 tdi fan supposed to spin with engine cold? notice that when starting from cold the V fan constantly spins My 109 thread
my youtube channel
Post #330757 13th May 2014 3:08pm
shaggydog
When cold it will spin with some resistance.
On start up it will spin right up to engine speed as the internals of the viscous coupling sort themselves out but after about 5-15 mins should sort itself out and become quite loose. Stop the engine and it should freely rotate if flicked.
When the engine is up to running temperature it should click in and start working hard making a more wooshing air sound when you open the bonnet.
Once up to temperature with the engine off it should be quite resistant to move and if flicked will probably rotate about 5-90 degrees if spun lightly. this means all is well.
If however it spins freely when engine is at running temp, but turned off, means the viscous coupling has failed and a new unit must be sourced.
Hope that helps Very Happy
Dog
Post #330772 13th May 2014 5:02pm
Retroanaconda
You have to get them quite hot to have them kick in. Normal driving, especially in the winter months, doesn't manage to lock it up properly on mine.
Put a big trailer on though and it locks up nicely, makes a hell of a racket and really moves a serious amount of air! Smile
Post #330831 13th May 2014 8:35pm
cornish rattler
Dog
Are that mite explain it then as I drove from wythenshawe to buxton 25 miles with no fan on then put the fan on for going off roading Smile Graham
Post #330914 14th May 2014 12:12am
