Home > Technical > Chassis repair pannel outrigger to radius arm tie
EMPI748
Scotland 2000 Defender 90 Td5 SW Baltic Blue
Applying a bit of rustproofing to my chassis today and stuck my finger through a bit of the bulkhead outrigger. Patched it about 18 months ago and it had been patched in the past so going to stick a new one on this time.
Can anyone tell me if there is a panel available to replace the top triangle bit between the outrigger, the chassis and the radius arm tie. Radius arm is STC8695 and outrigger is STC8354. Am i just miss visualizing it and it's included or is there a separate piece needed? There was metal below the bit circled and the radius arm, apologies for the poor photo only had my phone with no flash..
It's a 2000 TD5 if it makes a difference.
Stu
Post #330424 11th May 2014 9:45pm
EMPI748
Couple of slightly clearer pictures, I cut the bit between out as it was rotten:
Post #330501 12th May 2014 10:18am
