Home > In Car Electronics > Using a winch solenoid to turn on/off power to a winch
excossack
At the mo to power the winch (which also powers the front mounted jump start anderson connector), I turn a knob on the seat box, which is OK. But, I was thinking of using a switch like
http://www.mudstuff.co.uk/products/electri...-lock.html
to active a winch solenoid to power the winch.
Is this a sound thought? Would I need the same rating winch solenoid as the current winch which is a 12000LBS GoodWinch. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #329946 10th May 2014 4:29pm
landy andy
Could use
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Or
But for me one more thing go go wrong. Switch is simple.
Andy
Post #329955 10th May 2014 5:13pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I use a modified windows switch. That only works if you don't have electric windows off-course.
Oops picture from before switch installation. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #329999 10th May 2014 6:24pm
munch90
make sure the solenoid you get is Continuously rated on the coil pull in side as some solenoids aren't made to be switched on for long periods and the pull in coils get overheated
a lot of solenoids are only meant for short bursts of use
you need something like a remote battery isolator
Post #330001 10th May 2014 6:30pm
ex_mod_90
Something like this then: http://www.red-winches.com/products/albrig...lenoid/62/
I used one, worked a treat.
Rich.
Post #330339 11th May 2014 6:43pm
excossack
Cheers Ex-Mod 90. Sounds like the sort of thing I am after! 1999 Defender TD5 110
Regards
John M0VAZ
Post #330349 11th May 2014 7:11pm
landy andy
That will be the same as the one in my post then Whistle Whistle
Post #330471 12th May 2014 7:19am
Frowned upon by a lot of clubs as they insist on a 'physical' means of disconnection as above these solenoids can 'stick' on, just as winch solenoids 'stick' on which is why you want a means of disconnection.
Post #330487 12th May 2014 8:47am
munch90
sticking tends to be more on active load solenoids (starter and winch solenoids )
solenoids that connect then the load is put on them don't tend to stick as often
but yes all can stick just some more then others
always use good make and check they have silver contacts , the cheap ones have copper and they arc and stick
the safest are ones that don't rely on a spring pushing the contacts apart
Post #330490 12th May 2014 9:09am
The chances are you'd be fine with a solenoid but, if it were me, I'd keep the physical switch as well.
For my trayback I had a manual switch made by Albright at a cost in excess of £200 Shocked that can handle 500amps x 2 through two separate circuits so that I can isolate the front and rear winches at the same time
I have a spare if anyone is interested
Post #330500 12th May 2014 10:18am
munch90
yes that looks a good one , looks like when you push knob down it pushes contacts away and not relying on a spring
Post #330504 12th May 2014 10:26am
Here it is fitted in the FCX trayback
Post #330529 12th May 2014 1:53pm
Waldo
Sorry to drag this back up,
But does anyone know of a solenoid rated to at least 350Amps continuous?
That's the max draw on my warn.
Looking at the two on the devon site they aren't rated high enough..... Defender 90 XS TD5 (03 Reg)
Post #354157 28th Aug 2014 9:41am
excossack
I'd guess the solenoid on the warn winch would be good enough so could you use one of those? 1999 Defender TD5 110
Regards
John M0VAZ
Post #354180 28th Aug 2014 11:37am
Waldo
Apologies should have said isolator Banging Head Defender 90 XS TD5 (03 Reg)
Post #354285 28th Aug 2014 8:31pm
