![]() | Home > Tdi > EGR ECU removal |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
The EGR valve was blanked off years ago, now I wonder if I safely can remove the EGR ECU which is living under the cubby box. I want to replace the cubby box with a higher one, so want to get rid of the lost space under the cubby. I thought it only contolled the EGR, so it's obsolete now. Any thoughts? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
Just unplug it. makes no difference to the running of the engine.
Thanks, thought so but wasn't sure.
Cheers! ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
I must do mine at some point!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 ![]() ![]() ![]() |
Hi all,
I've just replaced my cubby box with a centre seat, but the EGR ECU doesn't seem to fit underneath the seat base. I'm I missing something or should the ECU be located elsewhere? I did wonder whether it should be in the battery box. Any advice please? Thanks, Andy |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
It should screw underneath the centre seat ,I've just removed mine this evening and thrown it in the bin.
Thanks,
Presumably it screws towards the front of the underside as this seems to provide more room. Regards, Andy |
