Home > Td5 > Fitting new ancillary belt
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Have brought a new belt and plan to fit it tomorrow. Have also acquired viscous fan spanner to remove this prior to fitting. Is there any tips on doing this as it is my first time Neutral
cheers Tommo
Post #329735 9th May 2014 7:26pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Takes about 10 mins, if you want to you can remove the fan cowl along top of rad panel note the route the belt takes move tensioner back and remove old belt. Fitting new one is just reverse oh and no need to remove viscous fan I would keep that in place on a td5 Thumbs Up 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #329757 9th May 2014 8:06pm
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
As above, definitely remove the plastic cowl. You'll also need a 15mm ring spanner to rotate the tensioner.
Quick and easy job.
Jon.
Post #329787 9th May 2014 9:43pm
Tommo
Thanks for tips. When the wind dies down I will have a go!!
Post #329814 10th May 2014 6:33am
landy andy
A tip I learnt was not to just release the auto tensioner, but to force it into the belt, it made mine quieter.
Andy
Post #329817 10th May 2014 6:43am
Tommo
Well its done but no thanks to LR Mad
I brought the belt from them and took me awhile to get the belt off (took it off underneath). Went to fit new belt but it didn't fit as it turns out they had given me a td5 discovery belt. Following a interesting conversation with the parts dept I re-fitted the old belt and collected the new.
Fitting the new took 2omins and now all is well.
One thing that caused me headache was getting the old belt back on but eventually worked out to slide it onto the viscous fan pully (once the rest was lined up) was the best way to get it on and it proved correct as the new one took 2omins.
Post #329893 10th May 2014 1:25pm
TD5_dan
Thumbs Up there you go bet you could do that in about 10 mins now you have the knack Laughing 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #329938 10th May 2014 4:03pm
Tommo
Well ill try and beat the time of 20 mins when I next do it...in about another 90k Rolling with laughter
Post #329998 10th May 2014 6:24pm
