Home > In Car Electronics > Switched power source
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Hi all,
As more and more gizmos are appearing in the cab of my 2010 puma sw I have decided to semi permanently wire in my various 5v and 12v devices. I spotted this on fleabay : http://www.ebay.co.uk/itm/201083546942?ssP...1423.l2649 which should take care of the 5v kit, the 12v I shall take off the same point that is supplying the voltage converter.
My question is what is the best place to tap in to obtain a 12v ignition switched supply. I reckon the load will be no more that 5a max.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #329300 8th May 2014 1:54pm
Cigrette lighter would be my choice, as it's separately fused (I think), so should things go wrong then only that circuit will be dead.
Post #329346 8th May 2014 4:37pm
kmac
Yep cigarette lighter as jim said - its got a 20AMP fuse.
You can also get one of these like wot I did and connect at the fusebox
[/img]
Post #329482 8th May 2014 9:28pm
ChrisCM
Yes, thats what I thought the cigarette lighter would be the best place, I've looked at the fuse box gizmo but I understand that you cannot close the fuse box after it's fitted?
Post #329616 9th May 2014 12:04pm
I doubt you could, make a tap section between the original plug and socket.
That way noting gets cut, all you need is some spade terminals and solder on a T joint and heatshrink, or use a tap but heatshrink would be better.
Post #329619 9th May 2014 12:10pm
gilarion
Should you require a 5V feed for a sat navigation device such as a TomTom make sure you have a 5v fast blow fuse in line. TomTom circuit boards are incredibly voltage sensitive and should for some reason that 12V 24V 40V to 5V 4 USB Step Down USB piece of kit spike, which some do, it could blow the TomToms board.
Post #329643 9th May 2014 1:24pm
kmac
Chris
Currently I have tapped into the wire directly for my reverse CAM and the dash cam
Was planning to use the piggy back fuse thing for the CB radio so not installed yet
Duh didn't think that the fuse box lid may not close.
Post #329748 9th May 2014 7:43pm
kmac
Tried it just now - no problems in a Puma - fits fine and fuse box lid closes with plenty of clearance
Will be using this for the CB power source
Post #329903 10th May 2014 2:22pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Is it possible to use a Fuse Tap in the Fuse box under the Drivers Seat?
I need to power a 100amp relay from a switched live, if so which fuse, as it would be easier to wire it from there. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #329950 10th May 2014 4:58pm
kmac
I would be vary of tapping in for a 100amp feed as I can't imagine any circuit has that much of spare load.
Given its a relay, don't you just need to power the switch on the relay from the switched live and get the relay power from a fused cable direct from the battery?
Post #329958 10th May 2014 5:18pm
NormanD
exactly, that the intent NormanD WE191
2015 110 XS Utility
Post #329977 10th May 2014 5:42pm
kmac
Should be no problem tapping from under the drivers seat as relays switch doesn't use much power.
However, i would double check with some of the sparkys on here ( such as munch90 I believe)
Post #329982 10th May 2014 5:46pm
K9F also is, just be wary though, you know what they say about sparkys. Whistle Rolling with laughter Rolling with laughter
Post #330005 10th May 2014 6:33pm
NormanD
Any clues as which fuse can be used? NormanD WE191
2015 110 XS Utility
Post #330289 11th May 2014 4:32pm
munch90
normal 30 amp relays only take a very small current (I think its about .3 of a amp on the switching side so really a feed just to switch relay can be taken from most fuses
not sure about heavy switching relays , but easy to check with multi meter
the feed to power something through relay I prefer to run from battery , run one heavier wire than needed for future gadgets (we all add more in time ) and saves having wires running off other things here there and everywhere
some relays have diode to protect the circuit from taking switching feed from , as relay coil field collapses it can sent a spike back up the feed wire and if you take a feed from some sensitive is not a good thing
Post #330293 11th May 2014 4:50pm
