![]() | Home > In Car Electronics > Fuses |
Being an electrician I can categorically state the third one down on the left is definately 'a bit dodgy.' My advice would be to change it sharpish.
![]() ![]() I would seriously consider ripping the fuseboard out and replacing with a Blue Sea. Time for a safe upgrade I think. ![]() For example: http://www.ebay.co.uk/itm/like/16116119344...p;ff14=108 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 30th Apr 2014 7:00pm. Edited 1 time in total |
^^ Yes, it looks like it may take a 10KV extended period short before it will blow........... eventually.
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Benzini Member Since: 26 Apr 2014 Location: Sleaford Posts: 10 ![]() ![]() ![]() |
haha my thoughts as well.
Should I match them all as close to the lid specifics? I'm not running a Landrover motor though and wondered if this would alter the fact. |
When you state you're not running a Land Rover motor I am unsure exactly what you mean. Presumably the circuits/systems being supplied are the same?
Stick to ratings as close to the original and you won't go far wrong. Certainly better than what you've got at the moment which is seriously suspect and unsafe in my view. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Best I don't share with you the other wiring issues on the truck!
![]() Thanks for your advice. Having not been in this country very long, are mobile auto elecs very common? Need one out to change a lot of the dash wiring. |
Yes they are but at a premium. I'm in the wrong job I think sometimes.
![]() Treat every day as if it is your last....one day you will be right!! |
