Home > In Car Electronics > Galaxy Tab 3 7"
excossack
Galaxy Tab 3 7"
Having just purchased a Tab 3 7" I tried charging in the car but it doesn't charge. The USB charger is a Blue Sea one and have tried both ports and also tried a adapter from a cigarette socket to USB and that doesn't work,
I tried the cables on a charger in work and it worked.
Does anyone else run a tab 3 7" and charge off a BlueSea USB adapter ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #324659 19th Apr 2014 10:42am
munch90
I found my Samsung wont charge from anything other Samsung charger when its dead flat , if its still got bit of life in it I can plug in to apple ipad usb charger (using Samsung lead ) and its ok but not if its dead
sorry not tried my blue sea usb on it
Post #324688 19th Apr 2014 1:10pm
gilarion
I use the mains charger off an inverter in the car seems to work fine. I never use anything other than genuine chargers for any tablet or phone, i just do not trust aftermarket products with sensitive devices
Post #324691 19th Apr 2014 1:22pm
excossack
I was just using two generic leads that I use for my phone and the wifes phone, which work fine
I have also just tried the genuine Samsung USB lead that came with the Tablet and that does not work.
The tablet is 87% charged.
Either
A) not enough current leaving the BlueSea / Cigerate socket USB convertor
B) Tablet uses extra pins for charging that works fine with a 240v plug in charger but not with in car ones
C) Other... 1999 Defender TD5 110
Regards
John M0VAZ
Post #324702 19th Apr 2014 2:34pm
Ragerover
Not the galaxies but with the ipad it runs different amps then an I phone
I've got a double plug in thingymabob and only 1 side does the pad
Post #324723 19th Apr 2014 5:00pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
It needs to be 2.1A plus to charge. I bought an adapter off of eBay that has a double output (says it's one for Apple, one for Android), it plugs into the standard Defender socket and works fine. My Disco 'best bits'
Defender 110 XS CSW 2013
Post #324725 19th Apr 2014 5:02pm
excossack
mmm shame. I was rather hoping my BlueSea would do the job. Off to hunt the bay of e. 1999 Defender TD5 110
Regards
John M0VAZ
Post #324730 19th Apr 2014 5:45pm
excossack
Just checked the specification of the BlueSea USB socket and the max output is 2.1A
Just tried it on a USB adapter like this http://www.ebay.co.uk/itm/NEW-3-WAY-CAR-US...20d4f189ef
and with an output of 500ma, the tablet starts to charge.
My thought, is the USB one above might have a different pinout (maybe an extra pin for charging) than the BlueSea one? 1999 Defender TD5 110
Regards
John M0VAZ
Post #324878 20th Apr 2014 12:49pm
excossack
My mate tried his Tab 3 8" on the same lead and sockets and that charged OK.
But in his car a USB charger he has charges mine but not his! 1999 Defender TD5 110
Regards
John M0VAZ
Post #325814 24th Apr 2014 12:20pm
