Home > Puma (Tdci) > Swivel seals
The Boy
Swivel seals
In the last 2 to 3k miles I had my right swivel seal changed twice and once on the left. Now I have noticed the right one is leaking agian. Now I heard there was a bad batch in late 2008 but mine is a 2009 (February). Has anyone had issues with these?
Post #26923 15th Mar 2010 7:03pm
fekete
I've had 3 sets on my 07 they found there to be a machine mark on the ball on one of them Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #26924 15th Mar 2010 7:06pm
The Boy
Yeah thats my guess too. When it went in second time I ask the dealer to check but I jsut think they bunged a new seal on.
Post #26925 15th Mar 2010 7:09pm
K9F
I had a front offside one replaced at 12000 mile service under warranty! Had I had to pay for it was surprised to see on the invoice it would have cost me £124 to have done! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26960 15th Mar 2010 10:27pm
Grockle
are the swivels free of chips etc which could snag the seal 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #26974 16th Mar 2010 8:16am
The Boy
Yes as far as I can tell. Have studied them on both locks and could not see any problems. The first 5k miles there was no problem but then after October it started. It could be a defected seal batch and the cold weather may play a part in focussing the problem.
Boy
Post #26975 16th Mar 2010 8:20am
quigley
Australia 2009 Defender 110 Puma 2.4 SW Alpine White
I had a problem with swivel axle seals weeping almost from new on a 1983 Range Rover.
It was an oil bathed rather than grease filled arrangement on that model.
I finally tracked it down to air pressure increase on heating up, forcing the oil out through the seals.
I ran a breather tube from the filler plug up high into the engine bay on each side.
I ran those seals for some 700k without excessive weeping or ever needing to change them again.
If your seals and swivel axle surface appear in good condition then I would check for pressure build up.
Look for weeping not only at the swivel axle seals but also at the diff pinion seal.
Check if the diff breather is obstructed.
Before going to the effort of fitting breather tubes, you could remove your swivel axle filler plug and substitute
some porous seal to stop rubbish getting in but allowing air out and see if the weeping stops. You would have to be sure nothing is going to get into the swivel axle, such as water, during your test.
My Puma seals do not weep excessively but I have only done a very low mileage to date.
Post #27414 18th Mar 2010 10:50pm
