Home > Td5 > td5 security
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
td5 security
hi all i have a td5 90 and have got a canvas which ill soon be fitting, obviously this makes her an easy target for thieves, she will have a tracker but id like to stop them taking her to start with, i was thinking about a switch in the ecu earth (accidentally found it wont fire without it lol) would this cause any issues being disconected for long periods? cheers Ed
Post #323569 13th Apr 2014 9:18pm
grafty99
Can't see any problems with leaving it disconnected, just check it doesn't do funny things to the immobilisation when you activate the alarm (assuming you have one?) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #323574 13th Apr 2014 9:30pm
Millsy94
No immobiliser or alarm hence my concern
Post #323589 13th Apr 2014 10:37pm
IF it's a Td5 then it should have the 10AS alarm unit fitted as standard (unless you've had a hybrid ECU made so the alarm unit can be removed), so you just need to get it activated, and then you can use the plippers and coil around the ign switch.
PM sent re hidden switch too....
Post #323600 14th Apr 2014 6:52am
