Home > Puma (Tdci) > immobilizer and alarm |
think you lock it with key not fob ,immobilizer is automatic on after 30 secs
but why do it , is alarm going off at night ? |
31st Mar 2014 9:02am |
Carrotious Member Since: 21 Mar 2014 Location: Geneva Posts: 24 |
I don't have central locking.
The alarm and immobilizer are switched on using a key fob. The problem is indeed the alarm going off at night. Its not doing it now but I have had a previous vehicle vandalized because the alarm was going off and I would like to avoid that. And anyway in a city for security reasons nobody pays any attention to a car alarm going off, its just annoying. Also it scares the life out of me every time i forget to switch the damn thing off and open the door. |
31st Mar 2014 9:49am |
unless its not the same as uk spec ,immobilizer should come automatic on after 30secs after ign turned off ,
does the red light start flashing after 30 secs after turning ign off ? |
31st Mar 2014 10:14am |
yes the red light under the rev counter comes on.
does this mean the immobilizer is on. I don't need to switch anything off when the red light is flashing to start the car. Just put the key in the ignition and start. the fob makes the indicator lights flash 3 times when i press the lock button and once when i press the unlock. |
31st Mar 2014 11:25am |
yes that means immobilizer is on , you don't have to turn it off as the fob has a transponder chip in it so when you put ign key in and turn on ign the chip sends a signal to turn immobilizer off automatic
so just lock with key and don't touch the fob and alarm should be off . and unlock with key then chip will turn off immobilizer off to start ,you don't have to touch the fob |
31st Mar 2014 11:50am |
ok that's good news...
I can test this i guess by trying to start the car without the fob near the car... |
31st Mar 2014 11:52am |
yes you can , cant remember if it wont start at all ,or it may start but only run for couple of seconds then cut out with no fob
31st Mar 2014 11:55am |
kool will test and post what happens
thanks for your help G |
31st Mar 2014 12:03pm |
confirmed... immobilizer and alarm not linked...
perfect... |
31st Mar 2014 7:15pm |
