![]() | Home > Td5 > Oil in loom |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 ![]() ![]() ![]() |
Bit of a length of string question. Why not just change the loom it's quick, cheap and easy to do.
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
NickEJ,
Is it main dealer part ? Roughly how much ? |
You'll need the loom and also a rocker cover gasket which together will come to about £45 if I recall correctly. They are available on-line for various prices but, as with most things, buy the best one you can. Mine's a Td5, I assume yours is too?
It took me 45 minutes to do at a leisurely pace and in the dark. The good news is that it's an instant fix. Only thing to watch out for is the seating of the rocker cover gasket in the half moon section at the rear of the engine, otherwise it's very straightforward. |
Thanks for the advice NickEJ.
Yes mine is a TD5. On with the search now for parts. ![]() |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
Once you've replaced the injector loom and cleaned out the red plug you will need to check the red plug there after every fortnight as you will still get the remainder oil working its way out, mine took another 2 cleans over a 4 month period. I also used electric grease on the plugs it does help..
Replaced the Injector loom & gasket today. Didn't find any oil in the usual plug. None at all.
![]() Click image to enlarge ![]() Click image to enlarge There was oil in the injector loom connections however. ![]() Click image to enlarge ![]() Click image to enlarge Doesn't seem to be running any better than before. At least that's one job out of the way. I'm no mechanic but found it pretty straight forward. |
