Home > Maintenance & Modifications > Masai spare wheel carrier
LR90XS2011
Anyone got any experience of fitting one of these?
eBay Item No. 281115069813
Masai Large Spare Wheel Carrier for Land Rover Defender 90 and 110
Fixes to the chassis to minimise rear door hinge strain
Other benefits include an offset position to maximise access to the rear door as well as increasing rearward viewing.
Replacement part number KTB500040
Suitable for station wagon, 110, 90 series
Suitable for large wheels too (see photo with large wheel in it)
Special hinged bushes with grease nipples to provide long-life and serviceable parts
Laser-cut with superior clean welding
High-strength steel construction
Zinc Galvanised for Long Life
Black thermoplastic paint finish
Complete with fitting kit, all nuts and bolts are stainless steel.
For Pre 2002 versions you can purchase an optional Strengthening kit - contact us if needed DEFENDER 90 TDCI XS,
Post #318893 25th Mar 2014 6:23am
theorangebandit
I do like the look of that swing the adaptor bracket for the door looks to use alk the original mount holes and is of a nice thick sheet of metal. I have added it to my wish list I'll definately be getting in touch to find out if it fits with land rover rear light guards.
Post #318906 25th Mar 2014 7:38am
theorangebandit
Post #318907 25th Mar 2014 7:39am
Apart from the Sonic carrier I found the Mantec useful my choices are limited though due to the NAS style rear step bumper the 50th offers a few other different challenges
Post #318909 25th Mar 2014 7:43am
leeds
OK biased warning, we sell the Safari Equip and Nakatanenga range of wheel carriers and have no personal experience of the Masai wheel carrier.
The Masai wheel carrier is made in Turkey and has a £10-15 price advantage over the UK made Safari Equip one.
The Masai one seems to have a smaller reinforcing bracket/fillet between the two arms.
The Masai one uses shorter fixing brackets then the Safari Equip one, and uses washers for reinforcing tub whereas the Safari one has a proper reinforcing bracket.
The Masai uses three long bolts supplied loose, presumably the space saving redesign to go into a smaller box as the means of attaching the actual wheel.
The Safari Equip uses a metal top hat with three standard welded wheel studs so that the rim is firmly bolted onto the carrier. I think this is a better and stronger design than the Masai
This raises the question what thread sizes have Masai used on their stainless bolts. Standard fine wheel studs thread or? I do know a stainless bolt manufacturer has recommended NOT to use stainless fine thread bolts for this application.
The Masai one has decent online fitting instructions whereas the Safari Equip website does not. However Land Rover Monthly does have a good online guide for fitting a Safari wheel carrier.
Hope that is useful.
Brendan
Post #318925 25th Mar 2014 8:32am
landroverdiver
I fitted one a couple of months ago. Really easy to fit, very good instructions, and well made. Also an improvement to rear vision as spare is offset. No experience of any other manufacturers, but Masai is worth the money.
Post #318936 25th Mar 2014 9:56am
theorangebandit
A question for you then brendan is. Do either if the swings you mention that are not the masai one, fit with rear light guards?
Post #319253 26th Mar 2014 4:07pm
g-mack
are there any pics of this S equip one? their website isn't alot of use! like to see one in situ! My 109 thread
my youtube channel
Post #319265 26th Mar 2014 5:32pm
SailingTom
Just for you G-mack Here's the Safari one on my old 110 Thumbs Up
 Defender puma dormobile camper
Post #319286 26th Mar 2014 6:53pm
VeeTee
Netherlands
And another Safari Equipe one in the wild:
 Cheers, Vincent
MySite
Post #319293 26th Mar 2014 7:13pm
g-mack
cheers guys, they do look good! My 109 thread
my youtube channel
Post #319294 26th Mar 2014 7:16pm
leeds
Thanks folks, saved me trying to dig out some photos.
Will they work with light guards? Not possible to give a 100% definitive yes or no.
Depends on actual tyre size and how far off the vehicle the light guards stand off.
We run 255/85/16 which are 33" diameter and they do clear the lights no problem.
Also am sure SE do a large tyre version. Am not sure exactly the difference between large tyre and standard version.
Brendan
Post #319301 26th Mar 2014 7:55pm
SailingTom
Brendan
I had a 285 on mine and it cleared fine (not the one in the pictures) I don't think light guards would work though due to the bracket being very close to the lights as you can see in the pictures it nearly touches the top of the top light.
It was a great wheel carrier though, I just wish I could fit another.
Cheers Tom Defender puma dormobile camper
Post #319316 26th Mar 2014 8:46pm
I doubt that would fit with NAS sized lights.
Post #319379 26th Mar 2014 10:27pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
it's a very tight fit, too close for individual light guards with NAS lamps:
You can't actually get a ring spanner or socket onto the nylok nut, has to be open ended from the rear & a socket undoes from the bolt at the top. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #319667 27th Mar 2014 11:44pm
