Home > Maintenance & Modifications > Rust around a rivnut - what to do?
Page 1 of 3 123>
ericvv
I have noticed this already a couple of years ago, but it is getting worse now. Bit of rust has developed around one of the painted rivnuts in the panel at the left of the rear door.
How do I solve this? Is this something that my dealer's bodyshop can take care of ? (they are pretty good) Can this be solved without having to drill the rivnut out?
Tks, Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #318408 23rd Mar 2014 5:16pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
You can clean the rust off with this:
http://www.bilthamber.com/corrosion-treatments/deox-gel
and then touch up the paint.
Post #318412 23rd Mar 2014 5:31pm
ericvv
Thanks Joe, but doubt Bilthamber is available here. And to order it from their site means fairly prohibitive shipping costs to Switzerland, they would be a multiple of the product cost...
Other ideas/suggestions?
Post #318421 23rd Mar 2014 6:10pm
Leenorthants
Hi
Hi, that's a pop or pot rivet not a riv nut, wipe a bit of rusteze or similar over it and touch up with the correct lr paint pen.
Post #318422 23rd Mar 2014 6:13pm
Can you get ACF50, Eric? If so, spray it liberally on the rivet and up underneath the full length of the capping(s). It appears that the capping undersides aren't painted, so the rust you're seeing is almost certainly indicative of more that's hidden. Darren
Post #318423 23rd Mar 2014 6:14pm
VeeTee
Netherlands
Eric, you can ask your pharmacist for some oxalic acid. Make a 10% solution and treat the rust with it. Flush with a lot of water and touch up with paint.
(if your pharamicist won't sell it to you, alternatively you can use teak cleaning solution - the main ingredient is oxalic acid).
This is safe for the paint and removes the rust and rust stains. We used this a lot on cars which had parked for several days in the close vicinity of railway stations and thus got a lot of rust stains from the overhead wires. Cheers, Vincent
MySite
Post #318428 23rd Mar 2014 6:22pm
VeeTee
Netherlands
To keep the water out of the gap between body and cappings, I treated the gap with black sealant.
 Cheers, Vincent
MySite
Post #318433 23rd Mar 2014 6:33pm
ericvv
Thanks all suggestions. First thing I will do is show it to the dealer. The truck is now 5 1/2 years old, so there still is the factory corrosion warranty in place until September, albeit I do know that this warranty in year 4 thru 6 is limited to "perforating rust" only.
What is the definition of perforating rust by the way? Think I can make a point that this here is not surface rust, but rust which possibly has started from inside that panel and now is creeping outside via that pop rivet.... So perforating maybe???? Still worth the effort to ask I think.
Will kepos, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #318435 23rd Mar 2014 6:36pm
ericvv
Vincent, I will try the dealer to take off the capping with that pop rivet to see if this can be called "perforating rust" which has started from the inside after water ingress....
Euh, by the way, your Swiss flag there is not the correct format. Rolling Eyes Believe we discussed that already at length earlier. Laughing
Post #318438 23rd Mar 2014 6:40pm
VeeTee
Netherlands
^^ Eric, about the flag - yes, we discussed that before. But I am reluctant to take of the other five flag stickers to adjust to an even spacing. So for now, I have to live with this shame... Embarassed Wink Cheers, Vincent
MySite
Post #318443 23rd Mar 2014 6:53pm
LR90XS2011
#2 for the ACF50 approach, spray up under the cappings, run it behind the rear corner cappings and wipe it around the rivet repeat annually DEFENDER 90 TDCI XS,
Post #318493 23rd Mar 2014 8:12pm
munch90
spray under all cappings with waxoyl , also stops the rust creeping out where caps are welded
blow lots up under the caps and wipe off paint work
if you can get a proper air powered gun to do it
Post #318503 23rd Mar 2014 8:26pm
ericvv
OK, I have heard so much praise about this ACF-50 on here that I decided to give it a go. Found a UK based ebay seller who will ship to Switzerland. So bought the below, hope it is the right stuff. Thumbs Up
http://www.ebay.co.uk/itm/ACF-50-Anti-Corr...5d4a63e9a7 You never actually own a Defender. You merely look after it for the next generation.
Post #318516 23rd Mar 2014 8:59pm
munch90
people who use acf50 seem to keep reapplying it
waxoyled twice in 7 years and as new
don't get me wrong I have got some acf50
but looking at some of the corrosion posts on forum on much later cars then mine , I've always used waxoyl or supertrol and mine ( luckily ) has no corrosion what so ever
ok it's no good if you want to paint over after ,but I prefer prevention rather then cure
Post #318521 23rd Mar 2014 9:03pm
ericvv
Well, we will first see what my dealer says about it, hopefully they will cover it under the still valid "perforating rust" warranty. If LR warranty do not accept, I will ask them still a quote to take off the capping and sort the issue out.
If that quote would be crazy here in Geneva, then my truck will go in May back to a first class Swiss body shop near Basel for re-Dinitrolling, and eventually I will ask them to check this all out and take that capping off and repair, repaint. Those guys are first class I know, and possibly a bit more reasonably priced than here in Geneva wonderland.....
In the meantime I would try out this ACF-50 product on it then.
Post #318537 23rd Mar 2014 9:25pm
Page 1 of 3 123>
