![]() | Home > In Car Electronics > Rear power supply for 2 work lights? |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1725 ![]() ![]() |
Hi there on my soft top ive fitted an LED rear work light using the 2 blank power terminal under the internal light guard (2011 puma 90)
On my next one im thinking of fitting 2 rear lights (light in question is an 18w 6 LED type). As its a low power LED type will I get away using 2 off that supply or is there another redundant power supply I can used? So would it have to work off a rear wiper power supply or heated screen? Cheers Tom Defender puma dormobile camper |
Thanks. Ill run them off that supply instead next time then, most only fit one but seems ill get away with it then.
Cheers Tom ![]() |
