![]() | Home > In Car Electronics > What adapter or wiring do I need? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
I'm not sure you'll be able to easily sort this, most adapters are vehicle to ISO. For that HU it looks like you'll want a female plug but most on the market will be male as you are wanting the reverse. HU to ISO and not vehicle to HU.
What year is it? Might be worth selling and getting an aftermarket unit which is ISO which you can simply hardwire in using male and female plugs. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Thank Steve. It's from a 2005 defender, your probably right, it might be simpler to just buy a cheap unit, I'm only after a radio really. Thanks
Only way you'd get away with it is chopping off the loom plug off of a write off from a scrapper but that wouldn't be easy and you'd have to identify the wiring. (Or possibly track down the plug part number by LR)
I'd recommend aftermarket and then plug it's ISO plugs into a hardwired ISO plug like: http://www.ebay.co.uk/sch/i.html?_odkw=ISO...p;_sacat=0 TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Here you go: http://www.ebay.co.uk/itm/Bmw-Rover-Mg-Car...1106106388
That harness will give you the plug that fits the back of your LR head unit. You'll have to work out the wiring to connect it to the vehicle but I'm sure the details are available on the net somewhere. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Nice one LRA - I looked but couldn't find that when I did, similar but not the same.
![]() To add to that adaptor then you'd just need this http://www.ebay.co.uk/itm/PC2-36-0-FEMALE-...2a22ff751a TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Brill, thanks for your replies, I couldn't find the female adapter anywhere, another problem sorted
