mrd1990
I took the lazy option for running wires from the under seat boxes by just hiding them under the carpet.
If you take the fusebox cover off below the dash, you can push the wires up along side the existing wires and they pop out the same hole as the wires for the radio unit.
The carpet works okay but if you have a lot of wires, you could add DynaPad on the middle section but leave a channel for the wires so everything is smoother and quieter at the same time, although I don't think it's thick enough to make a huge difference
27th Feb 2014 7:47pm |
mark_d
27th Feb 2014 9:52pm |
