  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Trailer light problems
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Hi From NZ, (defender 2008 Puma model)I had a old trailer with tail lights that were broken, brought two new ones, wired in left hand side tested all good, had to use trailer for one journey. came back connected up other right side new light, only brake light and indicator working, now both lights not working but both indictors and both brake lights working!!! but not lights as such, turned onlights no little green light in dash and only park lights not ordinary beam or high beam on switch but high beam works when pulling back on the stalk for flicking lights, fuses under drivers seat for low beam seem ok, high beam fuse? relay? trailer wiring causing faults? Trailer wiring was ok with old lights this morning any help appreciated
Thanks Simon
Post #25563 2nd Mar 2010 7:19am
