Home > Technical > Puma Alarm BBUS Siren and Loom
Page 2 of 2 <12
munch90
may only come on sw , not sure
Post #314701 9th Mar 2014 2:44pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Yep its for the self leveling head lamp motor
Post #314739 9th Mar 2014 5:43pm
kmac
Actually I have the leveling headlamp motors and I have connected them. What I have missed out is the indicator light on the side of the vehicle (or as LR calls them - side repeaters.
Will have to have a look at how I can access that - any ideas welcome
Post #314818 9th Mar 2014 8:04pm
110 John
Slide it left and it will pop out I used a rod or stiff wire to push through the repeater hole to the front taped the wire on and pull back through
Post #314820 9th Mar 2014 8:09pm
kmac
Thanks John - will have a go tomorrow.
Also the old harness is secured in two places by a pointed plastic clip which pops into a hole. How did you get these out?
Post #314825 9th Mar 2014 8:13pm
110 John
Well its clipped in 3 places I used the rods i have to enter from the hole up by the heater fan pushed it to the front taped the wire harness to it and pulled it back through because I didnt want to remove the plastic covers in the wheel arch therefore Ive just left the old harness in situation unplugged and taped up and tucked away behind the water bottle you could tyewrap the new harness to the old harness at both ends
Post #314829 9th Mar 2014 8:21pm
110 John wrote:
All fitted and working fine tell me this is the siren supposed to chirp when arming and disarming the alarm the new eec rules say no i think ???????
No chirp, just the indicator lights flashing on arm/disarm.
Post #314962 10th Mar 2014 10:57am
110 John
Yep makes sence as the horn dont beep suppose if i had the door open and tried to arm it would chirp as the horn beeps twice just to test thats all
Post #314963 10th Mar 2014 10:58am
Interesting question - I'm not sure if the mislock beeps the horn and the BBUs or just the horn. If you set the alarm off then both will sound (unless of course the battery is disconnected in which case on the BBUS will sound).
Post #314977 10th Mar 2014 12:51pm
Page 2 of 2 <12
