Home > Tdi > Alternator ?
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Alternator ?
Hi guys
Not that there is anything wrong with my alternator think its a ( 200tdi 65 amp ) but in time I want to fit a winch and wondered if its possible to swap it for a ( 300tdi 100 amp ) if so is it a straight forward swap or is there anything I need to do Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #308478 16th Feb 2014 12:15am
shaggydog
Why not fit a 200Tdi range rover one?
Think they are 100 amps and all you need to do is rotate the mounting bracket 180 degrees Thumbs Up
Post #308598 16th Feb 2014 3:55pm
Lou Sparts
Not sure if the connections are different on the 100 amp alternator, but not insurmountable. 2005 Td5 90 XS
Steve
Post #308600 16th Feb 2014 4:00pm
shaggydog
Depends, if you still have the original loom for the 2.4 NA or 2.5TD then the 200TDI fits the defender alternator and Range Rover as they are the same from memory.
I have a feeling they changed it for the 300TDI as that was when they upgraded the loom from bullet connectors to proper plugs so the alternator may have changed with the loom upgrade.
Ether way, I can't imagine it being a big issue to replace the old plug with one that suits your new one.
Alternatively if you have a 3 V Pulley you can add an additional alternator which could supply power to your winch battery set up and keep your starter motor set up separate from your winch and accessory battery?
Post #308603 16th Feb 2014 4:10pm
g-mack
i wasnt aware the 300 tdi was 100amps! i thought it was 65!! My 109 thread
my youtube channel
Post #308606 16th Feb 2014 4:18pm
shaggydog
Think it depends if it is a Discovery one or a Defender one, the discovery one is often higher as it is running more and things like air conditioning.
Post #308616 16th Feb 2014 4:53pm
g-mack
ah yea quick bit of research shows disco has a 100amp one! wonder if its a straight swap to defender? My 109 thread
my youtube channel
Post #308630 16th Feb 2014 5:55pm
Litch
A Disco 300TDi 100A alternator is a direct swop onto a Defender 300TDi but the cable will be rated for the lower output so will need to be replaced / upgraded. Both are lug connectors onto a stud.
Aprt from the 200TDi being a blade connector compared to the later one being a stud, isn't the earlier one a Vee belt? If so you will need to source the correct pully. ONE LIFE, GET IT!
Post #308634 16th Feb 2014 6:08pm
