Home > Td5 > Spare warning lights in dash panel..?
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have a TD5 Hardtop County, 2001MY.
Are there likely to be any spare warning lights in the dash panel..?
cheers
simon
Post #307434 12th Feb 2014 12:54pm
excossack
Is there one for a 120km/h warning light ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #307435 12th Feb 2014 12:55pm
couplands
Hmm, not seen that ...will check the manual..Wink
cheers
simon
EDIT: so I can see where it is in the manual, just need to figure out how to turn it on. Also noticed there is a choke warning light, so might see if I can use that. If anyone knows how to activate them, let me know..!
Post #307438 12th Feb 2014 12:57pm
excossack
I can just see the outline of the symbol on my dash panel (1999MY) 1999 Defender TD5 110
Regards
John M0VAZ
Post #307441 12th Feb 2014 1:05pm
Martin
Site Admin
These are all unused on UK spec:
120km/h warning lamp
Choke
Gearbox temp
You may also have an unused traction control warning lamp if you don't have ABS/TC.
The wiring pins and signals required to activate them are:
120km/h: 20 pin connector, pin 6 to ground
Choke: 16 pin connector, pin 2 to ground
Gearbox: 16 pin connector, pin 5 to ground
TC: 16 pin connector, pin 16 to ground  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307448 12th Feb 2014 1:40pm
couplands
Thanks Martin, just the job. Got ABS/TC, but one of the others should be fine.
Are the bulbs likely to be there, or do I need to install them..?
Simon
Post #307449 12th Feb 2014 1:43pm
Martin
Site Admin
There are no bulbs, they are LEDs and are all fitted.
If you need a wiring pin to fit into an empty position, let me know.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307450 12th Feb 2014 1:45pm
couplands
Brilliant, thanks Thumbs Up
cheers
simon
Post #307451 12th Feb 2014 1:49pm
shaggydog
Sorry to jump in but on my 200tdi very very occasionally the PTO light comes on, which is odd because it has nothing fitted and hasn't ever had anything fitted to my knowledge.
Without taking it out to have a look, is there anywhere I should look to see what it it attached to (and what occasionally wants attention?)
Dog
Post #307458 12th Feb 2014 2:22pm
udderlyoffroad
Couplands,
Have a read here:
http://www.retroanaconda.com/landrover/200...tdi300tdi/
It’s a guide to installing the Td5 instrument pack into older vehicles but he gives a complete pinout for the spare instrument warning lights. Some are ‘negative switched’ so you may have to switch them on via relay (create a ‘NOT’ gate if you will).
See below (PDF) for the owner’s manual which will show you the lights in the warning cluster and which are spare:
http://www.legionlandrover.com/manuales/us...5%20v8.pdf
Matt Real trucks don't have spark plugs
Post #307478 12th Feb 2014 2:59pm
couplands
Matt,
Great resources, many thanks... Thumbs Up
cheers
simon
Post #307480 12th Feb 2014 3:02pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
What controls the 120km/h light? Isn't that fitted to gulf spec or somthing?
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #307546 12th Feb 2014 6:13pm
Martin
Site Admin
A separate ECU on Gulf spec cars. For other markets the pin on the warning panel loom connector is empty.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307554 12th Feb 2014 6:44pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Just out of interest, did LR supply ROW petrol Land Rover post 1998, or did the 50th anniversary have the later "TD5 style" instrument panel? Trying to work out why choke would be on there. 1998 110 300Tdi White Hard Top
Post #307558 12th Feb 2014 6:49pm
Martin
Site Admin
The 50th had Td5 style clocks but the older style warning panel.
Don't know why the choke symbol is there, maybe added "just in case". Although it would only be for manual choke anyway, which was long gone on cars by the Td5 era.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307562 12th Feb 2014 6:53pm
