Home > Maintenance & Modifications > Tow hitch decision support required
alantd
Situation
I'm running a NATO hitch for my Sankey.
I want to be able to tow other things as well with a 50mm ball hitch (I already have the OEM adjustable setup which doesn't fit with the NATO holes).
I want to strengthen the rear cross member sufficiently that my NATO doesn't bend it under load (which I've seen)
I don't want to compromise my rear departure angle any more than I have to.
Solution 1
I was thinking that I'd create a modified version of the original adjustable plate - extended to cover the 4 holes in the crossmember that the NATO bolts to. That way I'd have the original tow setup, the NATO and a plate behind it to strengthen the crossmember under shear loads.
See diagram below:
http://www.defender2.co.uk/gallery/albums/...plate.tiff
However:
1) all towing gear has to be certified and tested. I was going to use mild steel 10mm - same as OEM - and the same design so maybe this doesn't apply?
2) it is going to cost £100 to get it made up!
3) with the NATO hitch in place, there's not a lot of space above the OEM hitch - might make it a pain to use
4) the NATO fouls on my spare wheel in the standard position and I can only open it with the rear door open. Great for security but a pain for attaching the trailer.
Solution 2
The alternative is to get an adjustable Dixon-Bate with 2 mounting plates, 1 for the NATO and 1 for the 50mm ball. I can then swap them around as necessary. I think the DB will provide sufficient protection for my crossmember. I'd then have full flexibility in height for the 50mm and the NATO would sit a little bit lower making life much easier when mounting the Sankey.
However:
1) it'll cost £250
2) it seems that the DB is actually lower than the OEM - compromising my already sh*t departure angle still further - anyone know whether this is true?
3) with the NATO in place, will the DB rattle like hell?
4) should I get a 1 pin or a 2 pin to attach the plate to the bracket? Will a 1 pin be strong enough?
Thoughts and wisdom greatly appreciated One that started out as a 2.4 TDCi 110 XS
Post #25136 25th Feb 2010 8:00pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
As i`ve mentioned before how about a safari equipe reciever type hitch Thumbs Up which allows you to swap between hitch types quickly Thumbs Up
Post #25144 25th Feb 2010 9:15pm
alantd
It's not that I didn't believe you Wink
I've just not seen them (can't find them anywhere online - where did you get yours?).
I assume this is it in your gallery
You have a Sankey-based trailer don't you? Does the hitch go high enough to pull in line with the Sankey and is it pulling through the centre of the mount? I can't quite visualise it from the photo - it looks like it protrudes too far to be very strong?
I do like the idea of being able to take it off though Very Happy I wish Southdown had modified theirs for the Puma. One that started out as a 2.4 TDCi 110 XS
Post #25149 25th Feb 2010 9:51pm
The Boy
I have a lr ajustable hitch on mine and I have to plates one with a ball and pin for work and one with the jaw for the sankey. Yes it is like a plough when offroad Laughing
Post #25157 25th Feb 2010 10:17pm
