Home > Maintenance & Modifications > Rear Wheelarch protection
Fish
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Thought I'd share today's activity as a newby. I've looked high and low and couldn't believe no one made a wheel arch protection kit for the rear. I've got a new MY14 90 XS and couldn't believe the lack of carpet etc. So rather than fit carpet and soundproofing (which may happen still) I thought I'd make some protection for the rear to stop the stones firing themselves into the Ali and quieten it all down...
I identified two captive bolts which fix the seat brackets in and removed the nut to change to two narrow nuts. The outside was wedged against the spats and tub side with rubber protection to stop it rubbing. This allowed me to fit a frame made form 3mm x 25mm Ali which I then riveted some 4mm reinforced rubber onto to provide the protection and sound deadening....
Took a little while and I also put a diagonal bracket at the front to hold the leading edge. The rear was just wide cable tied to the support bracket for the tub or the filler tube....
Hope people like the idea....
Photos below:
Mounting bolts and bracket position-
Frame to hold protection-
Finished job-
Hope people find it useful, I'm proebly getting a bit anal but enjoyed making it!
Post #306247 8th Feb 2014 6:52pm
Fish
Does anyone know how to make the images load??
Post #306249 8th Feb 2014 6:54pm
EDITED**
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #306252 8th Feb 2014 6:58pm
Fish
Ah I think it was because BBCode was disabled...
Now fixed Thanks
Post #306257 8th Feb 2014 7:02pm
GUM97
Looks nice, great idea! Thumbs Up An engine to TDi for!
Post #306271 8th Feb 2014 7:34pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
It will stop the noise of stones flinging from the tyres onto the tub, but you have created yourself a perfect mud trap. The wheel arch strengthening, for the rear seat fitment, will rot in no time if its kept damp behind your cover. Nice idea, but you may be causing yourself some long term issues there.
Post #306274 8th Feb 2014 7:39pm
Retroanaconda
I had considered this, as I reckon it will all but remove the noise from wet roads as well as the stone throw. Was looking at wedging one of those plastic inner wheel arches off later vehicles in, but they are a bit dear.
My thoughts on your solution would be to make it a bit more free draining, otherwise mud etc. will get trapped behind there. But nice work still!
Have you found it reduces wet road noise?
Post #306275 8th Feb 2014 7:40pm
munch90
I did double skin the archs in on my old tdi but done it in alley sheet and got it a tight fit enough to seal all round them , looked at doing the same to tdci but too many bits to fit round and I would only do it if it could be sealed all round ,as other have said it could make thing rot a lot quicker .
yes there is a market for a moulded arch liner that fit well
Post #306290 8th Feb 2014 8:03pm
Fish
yep did think of damp traps, however there are good gaps at the inside and none of it touches the wheelarch it is all held clear. I'll check it in due course as it is only 4 bolts to remove the whole lot! It also has the benefit of living in a dehumidified garage....!!
If it does trap I will report back and remove.
Post #306467 9th Feb 2014 11:06am
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I agree with borderterrier.... building in a future issue with corrosion.... making holes where you don't really need them is never a good idea, plus its just a huge moisture and mud trap.
Plus, I just don't get what the issue is... I've had a Defender as a daily drive for over 10 years. I have a genuine rear rubber load mat but that's it. Never noticed any issue with noise, stones or otherwise, from the lack of a liner on the rear wheel arches...
Each to his own though! Wink Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #306552 9th Feb 2014 4:51pm
Fish
Maybe I'll ultimately ditch the idea. There aren't any new holes drilled though and I don't think anything will build up....I'll see in a while and either ditch or not!
Post #306666 9th Feb 2014 8:52pm
landy andy
As long as you load up behind with a wax, I think they should be ok with a regular hose out.
Andy
Post #306678 9th Feb 2014 9:13pm
