Home > Maintenance & Modifications > Installing a Blue Sea USB socket
mobilecentre
Changing your cigar socket over to USB - for pre 2012 vehicles the same type of plug is found in the rear for the aux socket see http://www.defender2.net/forum/topic20319.html
First of all you will need a panel mounted USB socket a suitable range of which can be found here http://www.mobilecentre.co.uk/index.php?ma...60_228_243
The Blue Sea twin unit is used in this particular example found here http://www.mobilecentre.co.uk/index.php?ma...cts_id=792
The white plug is for illumination and is not used
With the aid of a small flat screwdriver the female spades can be removed from the OE cigar socket, suitably insulated and plugged directly onto the Blue Sea unit
We have found the odd dash panel where the hole is tight to get the USB socket in so some gentle sanding will be required on some vehicles
Post #306159 8th Feb 2014 1:58pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
In my 2000 TD5 I found it tight in the hole but it happily screwed through so with the locking is a very solid fit.
A great product. www.td5.org
Post #306233 8th Feb 2014 6:20pm
TJ101
Reminds me,, Really must get round to finding the one you sent down Tim !! Surprised California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #306266 8th Feb 2014 7:22pm
Retroanaconda
Are we to understand that this product also fits into the hole in the pre-2002 dashboard which is normally occupied by the cigarette lighter?
Post #306273 8th Feb 2014 7:37pm
me@td5.org
Yeap
 www.td5.org
Post #306297 8th Feb 2014 8:30pm
Retroanaconda
Excellent, just what I had in mind.
Thanks for the photo.
Post #306301 8th Feb 2014 8:38pm
me@td5.org
The car doesn't have to be upside down either Wink www.td5.org
Post #306304 8th Feb 2014 8:41pm
