Home > My Defender > Rear Heating
frogface65
United Kingdom 2012 Defender 110 Puma 2.2 USW Alpine White
Rear Heating
Been toying with fitting a rear heating system in my Puma Defender to keep management happy when she has been relegated to the rear by my son . Came up with a cheap and quite effected system by using a 25mm flexible conduit i sell for electrical use. i started by feeding into the left & right lower air vents then make a slit in the carpet (if you have it) and feed it along between the seat and the cubby box and cut it off just to the rear of the box/foot well . Cable tie to the safety belt braket.
it canals the warm air from the front without little loss to the front. Plus gets rid of the cold shoulder to by balancing the heat around the car.
if anyone wants the kits give me a shout. Thumbs Up
attached photos
Post #305414 5th Feb 2014 8:45pm
munch90
I see a series 3 years ago and someone had fitted a small house style radiator in the back and it worked a treat ... fitted along behind the rear bulkhead and piped underfloor to engine
Post #305463 5th Feb 2014 10:21pm
GSD
PM sent
Post #305468 5th Feb 2014 10:27pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
My V8 has a heater matrix and fan fitted in the cubby box with vents on the back and a potentiometer to change fan speed. Makes quite a difference in the back.
The kids complain of cold feet in the puma on long winter journeys.
Post #305489 5th Feb 2014 11:10pm
