Home > Technical > ABS |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
You sure it has ABS My 2011 "County" doesn't... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
31st Jan 2014 6:17pm |
jumbo Member Since: 21 Jan 2014 Location: Dublin Posts: 29 |
It stopped so well I presumed it does, there is certainly a fuse for it!
31st Jan 2014 6:27pm |
easydeluxe Member Since: 18 Nov 2013 Location: antwerp Posts: 55 |
if it's a Puma then the abs light lights up in the dash every time yoy start. It goes out after a few meters after it self diagnosed the system...so if you don't see an ABS light there isn't any on your defender. ABS is also always paired with traction control.
So you have both or you have neither...and the TC also has a light on the dash that lights up when the system activates. |
31st Jan 2014 6:44pm |
