Home > Maintenance & Modifications > Rear lamp guards |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 |
Just looking at all the pics I can find of these items (again)....can anyone tell me if the guards are attached by a couple of 'P' clips, which they hinge on, and are held on the other side through the existing holes via screws/self tappers (which need to be removed to hinge open to swap bulbs, etc).....
Mark 2011 110 XS DC Stornoway Grey |
22nd Feb 2010 1:38pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
From what I remember on mine. Each side has 2 P-clips (to hinge open) and on the othr side it had a screw and riv-nuts.
I will take a picture later if I remember Glyn |
22nd Feb 2010 2:48pm |
That'd be a great help - thanks Glyn Mark
22nd Feb 2010 2:55pm |
Had a spare minute so quickly poped out and took a couple.
Loks like the P-clips are held in place by drilling out the rivets and then screwing them in instead, then the other holes are marked nd drilled after once the guard can be held up in place. Please excuse the quality was using my phone: Landy needs a bath too!! Hope this helps, Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
22nd Feb 2010 3:05pm |
Good man... thank you Glyn, thats a big help. "Drill out the rivets...." helps me make sure they're lined up properly too!
Cheers fella Mark 2011 110 XS DC Stornoway Grey |
22nd Feb 2010 7:14pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6621 |
22nd Feb 2010 7:25pm |
Martin, muchly appreciated, thank you. Official destructions for me to follow, thanks!
22nd Feb 2010 7:42pm |
I'm just trying to use this link, but only seems to bring up a blank white screen now (worked fine before) - anyone know if it's just me? Trying to find LR destructions for front light guards too. Mark 2011 110 XS DC Stornoway Grey |
28th Feb 2010 3:59pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
Not just you - the site's down Peter
2008 SWB Truck Cab 1952 80" Soft top |
28th Feb 2010 4:02pm |
Thanks matey Mark
28th Feb 2010 4:03pm |
