Home > Puma (Tdci) > Battery going flat!!!
Page 3 of 3 <123
K9F
Re: Bu99er!
konabikes11 wrote:
i have as above except that i have only one 87 terminal of which one positive goes out to the front along with earth then on my abar there is a splitter one for earth and one for positive (turning the one 87 wire into two one for each light)
That's fine! I wired mine up independantly with two separate relays and heavy duty wiring to afford me the option of upgrading bulbs further! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #25124 25th Feb 2010 4:57pm
problem is they will not work now as wired above. Confused the trigger is the head light wiring and when i connected the constant live back up today started engine put lights on and switched to main beam nothing only just the LR main beam. but before i did that i used multimeter and it was reading 0.00A not 0.16 which solved the battery problem thank goodness. my fuses are 20A
Post #25125 25th Feb 2010 5:18pm
Page 3 of 3 <123
