Home > Puma (Tdci) > LH Drivers be aware!
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Not sure if this has been discussed but I was reading LROI and came across this!
If you hear a banging noise when at full articulation in extreme off road conditions then it is the front propshaft hitting the sump on the engine! Their is a modified sump out which your dealer will fit if you complain of this.
EDIT-This only seems to affects Left Hand Drive vehicles! Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #1743 31st Mar 2008 9:52pm
TJ101
Yep,, see http://www.defender2.net/forum/topic222.html?highlight=
The modded sumps are on back ordered at present, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1744 31st Mar 2008 9:59pm
Maverick
Oops, fought that was something else! Embarassed Ben
Post #1745 31st Mar 2008 10:00pm
TJ101
No problem,, It would seam, it may not be only Left hookers !!
Not seen under a LHD, but can not see how they are any different !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1747 31st Mar 2008 10:12pm
jst
i believe its LHD and RHD vehicles, as Tim says how can it be any different, sump and props are in the same place. i think its more a case that the terrain they are used in o/s is different to the uk ie rockier therefore there were only LHD failures. Italy had the first failure i believe. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1904 18th Apr 2008 7:42am
