Home > Td5 > Water Ingress through roof
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Hi Guys,
I am sure there a lot of water ingress topics on here, but non that i can find about the top A-pillar corner to roof!
I have water coming in from above the A-Pillar but i cant work out exactly were from. I have pulled all the old Dum Dumb tape and re sealed it with silicon, but its still pouring in. Can anyone suggest anything or give advise?
Post #301173 22nd Jan 2014 11:59am
mk1collector
I just resealed mine up as it was coming in at the top of the a post. If you look at the roof line at the front and follow it down to the gutter I found a hole where the two meet that let a lot of water in.
Post #301181 22nd Jan 2014 12:21pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
The beauty of this stuff is that it finds the leak for you! Laughing
http://www.captaintolley.com/ "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #301191 22nd Jan 2014 12:33pm
K9F
Start at the beginning and work your way through...... Thumbs Up
http://www.scribd.com/doc/17833628/water-ingress-manual If you go through life with your head in the sand....all people will see is an ar5e!!
Post #301200 22nd Jan 2014 1:08pm
charliebaja
Thanks for the help here guys, I have bought some Capt Tolley's Creaking crack cure and hope that it finds and seals the water issue. I will update all when finished as to the results.
Post #301224 22nd Jan 2014 2:48pm
VeeTee
Netherlands
I also had water ingress at the corner of the roof and A pillar. Took me couple of years to find it! There was a tiny pinhole in roof corner at the rear end. The water in the outer gutter entered there and travelled along the inner gutter forward to the A pillar. First time braking or cornering after a rain shower the water would land on your knee! Shocked Cheers, Vincent
MySite
Post #301246 22nd Jan 2014 4:09pm
Gareth
Capt Tolleys Creeping crack cure is good. I used to seal the alpine windows and side windows on my 90. Its still good after a year. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #301261 22nd Jan 2014 5:04pm
landefender
France 2002 Defender 110 Td5 CSW Barolo Black
water ingress
where can I get hold of this magical Captain Tolley creeping crack stuff
Thanks in advance for the rply
Walter
Post #303962 31st Jan 2014 11:53pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #303970 1st Feb 2014 12:55am
landefender
water ingress / Captain Trolley
Thanks for your swift reply. I only hope that they are shipping to France. Can't wait to try it and will make my experience known
thanks again
Walter
Post #303989 1st Feb 2014 8:48am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Didn't they print an updated water ingress manual?
Post #303990 1st Feb 2014 8:49am
landefender
water ingress
I have the downloadable pdf manual, but I feel that I have to look further than what the manual gives me. So, I am banking on the Captain Tolley methode. Thanks for your post anyway
Walter
Post #304046 1st Feb 2014 11:26am
charliebaja
the Captain Tolley is very good, but i now see that the water is coming in from further down the car, perhaps the top window in the middle. I might have to pull it out to check. I cant see any other holes anywhere in the back.
Post #304886 3rd Feb 2014 10:39pm
borderterrier
The window in the middle, you referring to the alpine windows? Capt Tolley will sort them out, just make sure it's been dry or a few days and there is no water in the gap. If there is if has the effect of watering down the sealant as it is water based.
Post #304900 3rd Feb 2014 11:00pm
