![]() | Home > Tdi > Glowing battery light |
All 101s suffered from that.
If it's not causing any charging problems forget it. ![]() |
Only real way to tell is stick a voltmeter on your battery and compare readings static/engine running.
![]() Treat every day as if it is your last....one day you will be right!! |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
I would suspect that it is dieing or at least the voltage regulator is on its way out. Also clean the contacts for the wires on the back of the alt. Rhubarb and custard let fly with their secret weapon.
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
I had this on my 300, replaced alternator and it fixed this 1998 110 300Tdi White Hard Top
TJN Member Since: 03 Sep 2012 Location: Winchester Posts: 6 ![]() ![]() |
Sounds like youve got muck in the alternator. Clean all the connectors and air blast the alternator if you cant be bothered to remove it! worth checking your battery terminals too.
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Doesn't take long to remove the alternator.
Once out there are 2 or 3 nuts to remove and the thing comes apart. Then it can be given a good clean, and you can also inspect the brushes - they may be worn completely, with nothing left. A new brush and diode pack can be obtained rather cheaply. Much more likely that this is the problem, rather than spending a load of money on a new alternator. |
