Home > Puma (Tdci) > How to remove ECU on 2.2 Puma
SkyFallSilver
Kuwait
Hello,
Just called BAS and I am now tempted to have my ECU remapped for more power and remove the limiter.
Any tutorial on how to remove the ECU as I want it shipped to the UK 2016 Defender 90 Adventure Edition
Post #298625 14th Jan 2014 10:00am
SkyFallSilver
Kuwait
Managed to get it out, already at Fedex in transit to BAS for a remap 2016 Defender 90 Adventure Edition
Post #298693 14th Jan 2014 12:35pm
pascal
Cyprus 2013 Defender 110 Puma 2.2 XS DCPU Indus Silver
how did you remove it, need help to remove mine too...
thnx
Post #337484 11th Jun 2014 1:14pm
Two bolts hold the sound deadening cover on the top front of engine, remove and then lift cover off.
The ECU is at the rear on bulkhead.
Pull, carefully, the two plastic cable holders that look like they are nuts, this reveals two actual nuts that hold the ECU in place - remove the nuts.
The ECU has three connectors on the left hand side, carefully disconnect and then lift the ECU out
Post #337497 11th Jun 2014 2:01pm
