Home > Puma (Tdci) > puma alternator sense wire
110dc
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
hi I want to fit a split charge relay & two batteries to my car where do I pick up the sense wire from ? the one that only has a feed to it when engine is running .any one able to tell me its colour or even if you have done this job how you managed it . its a 2008 puma . much thanks stuart
Post #298056 12th Jan 2014 1:19pm
landy andy
I used a voltage sensing relay. It has three connections, one for earth, and two positives, as soon as the primary positive senses 13ish volts it activates the relay, joining the batteries so both are charging. So it's sensing wire is just the normal battery connection
Andy
Post #298059 12th Jan 2014 1:25pm
landy andy
Post #298060 12th Jan 2014 1:27pm
110dc
thanks but I already have bought a relay & it needs a signal from a circuit that's only live when engine running
Post #298088 12th Jan 2014 4:27pm
VeeTee
Netherlands
I think you can use the feed to the charging light:
 Cheers, Vincent
MySite
Post #298091 12th Jan 2014 4:36pm
munch90
most modern alternators have more than 1 small wire (most have a multiplug ) and are engine ecu controlled ,so be careful what you connect too!
does the wire have to go to alternator could it not be connected to a ign live wire so unit is only on when ign on.
does the unit sense voltage or just need a live ?
if just needs a live then a ign live will do ..
ok if you were sitting ign on but not running then unit would be on (but I would not sit with ign on for anytime anyway).
if you only want it on when engine running then I would fit a voltage sensing relay as feed for that can come from battery as that would on switch on when engine running (alternator charging) .
be honest I would not want anything connected to alternator small wires on modern engine
Post #298146 12th Jan 2014 7:37pm
Durite do several VSR's, from hulking great things that have an in built relay, down to smaller ones that can trigger an external relay.
Or if you wanted to keep it "LR", then use the VSR off of the 200Tdi defender that ran the heater rear screen...
my old 200 was a poverty spec one with a 65a alternator, and came with the VSR for the HRW (how many accronyms?)... if I came to a standstill with my main beam on and heater blowing full, the rear window would turn off Rolling Eyes
Post #298260 13th Jan 2014 8:53am
110dc
thanks think ill try an ing live circuit to try it seems easier or maybe look at a different relay
Post #298267 13th Jan 2014 9:21am
leeds
It sounds like the system bought is something like an X-charge system from X-Eng or similar.
Have a read of X Eng instructions on www.foundry4x4.co.uk.
Ignition fed live could also be taken from the back of the radio.
Brendan
Post #298269 13th Jan 2014 9:26am
110dc
It's something I've made up from parts sourced from eBay. Thinking about it I will probably try and use the feed for heated windscreen as that only works while engine is running
Post #298438 13th Jan 2014 8:26pm
