![]() | Home > Maintenance & Modifications > Home-made LED halo headlights |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
As matter of interest how did you wire them up?
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
The first set I had were wired up to the sidelights. The second set I put on my current 110 I decided to disconnect the wiring harness from the dim dip resistor (it's under the offside front wing) to the headlights and connected the LEDs to the supply side of the resistor. That way the LEDs get a full 12v when the side lights are switched on. When the headlights are switched on the LEDs are turned off. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
grommit Member Since: 10 Jul 2015 Location: England Posts: 7 ![]() ![]() ![]() |
wow... nice job, very impressed, british ingenuity at its best
