![]() | Home > Td5 > Swivel pin housing oil (grease) renewal |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
TD5 use a fill for life or one shot grease,so strictly speaking not servicable,I think the others use a gear type oil. Pov.spec,ftw. 2006, 110,TD5.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
There,s no swivel housing drain plug on Td5 (or 300 Tdi) so would be rather difficult to change the grease ! I just squirt a little in at service time as they weep ever so slightly. 2005 Td5 90 XS
Steve |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Once a year I used to put half a sachet into each side. Easy to do once you get the grease hot.
Andy |
