Home > Puma (Tdci) > Tapping onto the alternator cable
Page 2 of 2 <12
VeeTee
Netherlands
ZeDefender wrote:
I like the Dutch version - just pull off the light connectors then reconnect one light connector to the harness. Connect the harness to the lights and to a permanent + and earth. Not very versatile but does the job Thumbs Up
I also like this version (off course - I am Dutch Whistle Laughing ). I have it installed approx 4 years now without any problems. Before that I killed 2 head light switches within a few days because of melting contacts in the switch.
ZeDedender, I did tap into the feed from the alternator, was very easy, but I have a 300 Tdi - don't know if there is much difference with the Puma alternator setup... Cheers, Vincent
MySite
Post #295591 3rd Jan 2014 11:48pm
ZeDefender
Apparently the Puma is a bit "awkward" (in so many ways) compared to earlier models but that's okay. Originally I rigged it (in a rather ugly way) to the battery to test it (until I got LEDs) it so I'll just find a neater solution. In any event, there's a hell of a lot going on in the battery box already, so another wire won't hurt Wink Tell someone you love them today because life is short.
Post #295643 4th Jan 2014 11:15am
K9F
Matt,
As with a builder's house looking like a building site my battery box as an electrician looked a bit like a bowl of spaghetti (albeit a safe one). I decided to tidy the lot up and run in new cables for future use too. I used a Blue Sea 6-way and sorted it all out in one go, worth the efoort and makes future installations so much easier.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #295679 4th Jan 2014 1:38pm
ZeDefender
Shocked Wow - that is extremely tidy!
Perhaps verging a little on the OCD don't you think Whistle
Laughing Thumbs Up Tell someone you love them today because life is short.
Post #295733 4th Jan 2014 6:26pm
ZeDefender
Afterthought:
My only final decision re. the lights is whether to rig them to the main (starter) or auxiliary battery (via the BlueSea fuse box). One advantage might be that there will be no current drop with the second battery on starting as it's not normally connected. Also, even if the second battery runs flat, I can always connect the two while it charges. I can't help wondering if I've missed something though? Tell someone you love them today because life is short.
Post #295734 4th Jan 2014 6:31pm
K9F
I do admittedly suffer from mild OCD. That's why I'm so appreciated in the 'Marine Bodge It And Scarper Bigade' I still work to military aviation standards - Takes a little longer but only has to be visited once.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #295764 4th Jan 2014 7:42pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi ZeDefender,
regarding tapping power from the alternator in a Puma defender, it is quite easy actually.
just on the driver side of the engine, you can find the alternator and the power(positive) output nut is quite exposed with a rubber cap on it. if you open the rubber cap, you find yourself a nut securing the main power cable to the car battery.
what I did was put addtional wire there and tap the negative on the air con fixing nut.
just want to confirm that, I believe all puma defender are fitted with relay to the headlights?
they are the R122 relays on the diagram?
THanks
Martin
Post #300765 21st Jan 2014 2:06am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Difficult alternator..2.2 Puma
Thank you very much for this info.
Had a look today where I could fit the headlight loom - and saw this rubber covered nut. Was unsure whether it was positive though - as I could not see any other connections to the alternator.
Looks as if with some loosening of the pipe to the air box one could reach this pole a little easier - the effort obviously would be more worthwhile if one knew beforehand this was the correct polarity connection.
Will wait till I have more time available - and will try to post pics along the way.
Post #495962 24th Jan 2016 10:46pm
Page 2 of 2 <12
