![]() | Home > Technical > dimmed headlights on sidelights |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5824 ![]() ![]() |
One will have been fitted with the dim dip system, the other has not. All standard land rover, that there are no definite rules to which ones had it fitted to.
Andy |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 ![]() ![]() ![]() |
Thanks andy.
I presme there is no easy way to disable the dim dip on the main beams, as this confuses the hid ballast and, although gives a nice disco flashing effect, i doubt it does them much good ![]() Cc |
Never heard of Defenders fitted with such dim dip. Are you sure that it is not a matter of bad earth here?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
dim dipped lights were fitted to land rovers and many other cars in the uk , BUT were dropped after a while as the uk was prosecuted by eu commission for fitting them .
UK were only country to fit them QUOTE FROM NET In 1988, the European Commission successfully prosecuted the UK government in the European Court of Justice, arguing that the UK requirement for dim-dip was illegal under EC directives prohibiting member states from enacting vehicle lighting requirements not contained in pan-European EC directives. As a result, the UK requirement for dim-dip was quashed. good ole EU !!! |
Maybe I do not understand the term dim dip correctly, but is this the equivalent of todays DRLs? Meaning that when the contact is turned on or the engine is running, the high beam automatically comes on at reduced force?
If that is the correct understanding, then there should be no connection with side lights on or not. But maybe you talk about something totally different here. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric that's pretty much it, 1/2 brightness.
if you look behind the main dash, there may be a pink relay, that's the dim dip relay, it can be bypassed with a simple 3 wire harness, i did it to my 1995 90, I think the details are on LR4x4 forum |
the dipped beam part of main headlight came on at reduced brightness with sidelights
used a relay and resistor give lower output my 93 defender had it- but higher wattage bulbs burned resistor out so never worked anyway Last edited by munch90 on 30th Dec 2013 8:55am. Edited 1 time in total |
I see. So the UK were very proactive back in the 80's and 90's as to vehicle legislation.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
what happens is that when the lights are in the sidelight position on the switch, the main beans come on at reduced power. thinking about it it seems sensible for additional visibility. and i wouldnt have thought twice if the other 90 didnt do it.
this is not an issue of earths, as in my experience one would see variations in light output and these are at a constant level. Anyway I will ditch the HID on this one and search out some better bulbs. CC |
Aha....cheers for that CC |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 561 ![]() ![]() ![]() |
Why don't you just bypass the dim dip function (the relay is located behind the instrument binnicle) I've had to do to 2 of my mates as the resistor had gone faulty and the headlights didnt work, do a search and I'm sure it will show you how
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 ![]() ![]() |
my 2007 90 [hardtop - commercial] had/has dim-dip standard... I was told, at the time of purchase, that ALL commercial Defenders had dim-dip while the station wagons had headlamp adjusters/motors
Interesting, never seen a Defender on the road in any continental Europe country with dim dip lights. Seems a UK specific function I guess.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Even simpler than that, just unplug the dim dip resistor
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
