Home > Maintenance & Modifications > Convert Double Cab into Utility/Station Wagon?
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Hi,
Is it possible or should I say, how possible is it, to modify a Double Cab Pick-up into a Station Wagon / Utility vehicle?
Is it just a case of swapping the roof and rear door, and remove rear panel (that has the sliding window) and install the side panels?
Or is it much more complicated?
L
Post #23685 5th Feb 2010 9:10pm
alantd
That's basically it. You'll need the whole rear (door and it's surrounds), including the 3/4 windows if you want them. you'll also need to extend the wiring loom for the 3rd brake light and rear window demister, load bay light..
I don't know whether there is somewhere on the DC loom for rear door central locking.
The only other thing to think about will be the rear bulkhead. You might need to take that out.
Other than that it'll just be cosmetic. (soundproofing...). One that started out as a 2.4 TDCi 110 XS
Post #23692 5th Feb 2010 9:27pm
Woody3
Thanks for that Alan...I didn't think of the wiring loom for the rear brake light etc.
Hmmm...
Post #23729 6th Feb 2010 6:22pm
