![]() | Home > In Car Electronics > Td5 heated windscreen wiring |
I can only go by Puma experience sorry but this may help perhaps?
Multimeter would be your best bet to ring the cables out. Generally black should be the earth. The earth to the timing unit is switched by the dash switch, the timing unit then energises and puts a 12v supply to the coil of the heated screen relay which then places another supply onto the element. Basically there should be two fuses for the circuit a 5 amp for control and a 30 amp for heating. With a multimeter and playing around with the fuse you should be able to figure which is the earth and which are the supplies. Good luck! ![]() Treat every day as if it is your last....one day you will be right!! |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
heated front screen switch td5 pin out
pin 1 KO pink/orange to pin 5 on the timer pin 2 RO Red/orange + 12v Dash Inundation pin 4 B Black = bat neg pin 5 PS Purple / slate/ gray to pin 87 on Relay heated front screen hop this helps |
Blew up your link to assist.
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
thank K9F
Managed to 'piilage' it and find the original location before you edited the post.
Domfish Member Since: 24 Oct 2012 Location: Tamworth Posts: 40 ![]() |
Cheers for the diagram but seems wires not what they should be as fuse goes pop again. Best get tester out
